Hi, my Mppt charge controller has been working fine and now the state is off during the day. I’ve checked all the connections, fuses, etc, all good. I’ve reset the controller, but no luck. Any help would be much appreciated. Thanks in advance.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Hi @Saltysails
Did you know that you can press the "Why is the charger off" text and then you get an explanation on why the charger is off?
Asking because we see this question quite a lot on the community and this functionality was added specifically for these cases. But if people do not know it / find it, then apparently it is not clear.
Kind regards,
Thiemo van Engelen
Hi @Saltysails
You say: "My PV was above 5 volts", but it needs to be 5V above the battery voltage. When this is also what you meant, how do you know for sure, as the MPPT is reporting a low PV voltage that is lower than the battery voltage in the screen shot? Did you measure it at the MPPT terminals while the panels where still connected or perhaps after disconnecting the panels?
This is not meant as criticism, but just to be sure what is going on, as there is quite a difference between the possible problems here:
1. The MPPT did not measure the correct PV voltage.
2. The MPPT put too much of a load on the PV panel so the panel voltage dropped too much.
3. The text in VictronConnect is not clear enough that the voltage needs to be 5V above the battery voltage.
Kind regards,
Thiemo van Engelen
Pv voltage is lower than battery voltage. Check the voltage coming into the MPPT with a meter and see if it agrees with the app. If so then you have a connection problem somewhere between the panels and the MPPT. If not, then try resetting the MPPT. Disconnect pv first, then battery. Leave for 5 minutes the reconnect in the reverse order.
Thank you Derrick Thomas, I followed your reset instructions and now it works again! This problem is solved.
Mine is off also but being non technical in this unsure what the problem is.
35 People are following this question.
