Problem: SOC jumps from 95% to 100% when charging with the Smartsolar MPPT 100/30, I asume it is because it meets the conditions of "voltage as charged"
System:
- Multiplus II 24/3000
- SmartShunt 500A/50mv
- Smart solar MPPT 100/30
- Cerbo GX
- Battery balancer
- Battery bank center point monitoring
- 690A AGM 24V battery bank
After watching the video by Johannes regarding the correct set up of a BMV monitor, I am not sure of my case and I have 2 questions for this community:
- What values should I enter in the SmartShunt to solve this problem:
Charging voltage setting(VC)
Tail current setting
Further settings
- Does this not affect the SOC measurement if I charge with the Multiplus II.
Thank you very much in advance for your help
