Hello everybody,
I'm equipped with 4 Batteries (12V 225Ah) connected in parralel to get 12V 900AH total.
I'm charging this with a Quattro, and also an Mppt (from my solar panels), but i liked to be sure that each battery is charged correctly and at 100% !
I understand that the Quattro or the MPPT will give the charge tension value, but it will be for an average of this 4 batteries. Could i use a Argo Fet or Cyrix to regulate and manage the charge correctly for each batteries ? I understand that the Argo Fet as only 3 output, i'll need 4 in my case! Do you have any advise for a perfect configuration ?
Thank you.
Best regards.
