ths avatar image
ths asked
Cerbo does not connect with tank sensors
Sailboat - have a Cerbo GX attached to a Smartshunt; to 2 MPPTs and a Orion T-smart for the bow thruster.
In addition, 3 x tank + 1 temp sensors. When filling tanks after launch the tank sensors did not respond and I noted that the temp. sensor also appeared frozen. Checking history on the VRM portal it appears that something happened as I did a short on-land run of the engine. Battery monitors work all right.
Removed the Cerbo power cable for a restart and got message "No tanks found". No tank gauge is listed in the device list in the configuration menu. Any suggestions?
cerbo gx
Hi @ths
Have you checked that the tank sensors at question are enabled in the Settings > I/O > Analog inputs menu?
ths avatar image ths commented ·
Thanks for your reply Stefanie. The "Analog inputs" menu does not show up in the I/O menu - only "Digital inputs" and "Bluetooth sensors"
Stefanie (Victron Energy Staff) avatar image Stefanie (Victron Energy Staff) ♦♦ ths commented ·
Maybe try again with a reboot (Settings > General > Reboot). If that doesn't help, unplug power from the Cerbo for a few seconds. The last resort is to factory reset the Cerbo and set it up again. The procedure is described here in the manual here:
https://www.victronenergy.com/media/pg/Cerbo_GX/en/reset-to-factory-defaults-procedure.html
ths avatar image
ths answered ·
Again thanks Stefanie, will make a try on this.
ths avatar image
ths answered ·
Stefanie, sorry to bother you again - did as described including the factory reset but the Cerbo still fail to detect the tank & temp sensors (battery monitor works). I/O shows only "Digital inputs". Could it be a hardware failure?
4 comments
derrick thomas avatar image derrick thomas commented ·
You might try doing a firmware update in the cerbo. If already on the latest version you can revert to the stored version then update again.
Just to make sure, you have a Cerbo GX and not the Cerbo-S GX, right?
Yes, the Cerbo GX, with 4 resistive tank level inputs and 4 temperature sense inputs
If the tank and temperature inputs do not appear in the I/O menu, there may be a hardware issue with your Cerbo, whatever was casing this. I recommend getting it repaired or replaced under warranty by the dealer you bought it from.
ths avatar image
ths answered ·
Thanks, will do
