Quick question, I'm struggling to find the exactly answer to.
Scenario:
A Multiplus 24/800/16 is configured for AC-Ignore = true based on battery voltage using the "Dedicated AC-Ignore" Virtual switch.
The Multiplus is inverting and supplying a 700W load.
While the battery voltage and everything else remains the same.... the multiplus "derates" due to temperature to 650W.
Does the multiplus:
Switch back to AC-Ignore = false and fail back to AC-In as it would for battery voltage (for example).
Cut out and reset, dropping the AC-Out entirely.
Something else.
If the desired behaviour was to switch AC-Ignore to False and fail back to grid until either the inverter pro-rates again or the load reduces.... Can this be configured?
