Francisco Aroca avatar image
Francisco Aroca asked
ESS backup for a full house when power outage
A customer wants to have his PV installation working ok and have electricity in his entire house, even if a power outage occurs.
I am planning to connect the mains to the AC-in and all the distribution board to the AC-out of a well dimensioned MultiPlus-II. Also install PV panels, MPPT, BYD battery, Venus GX and an energy meter.
Will this ESS system provide backup and normal performance even in the event of a power outage?
I am not sure all Victron devices will continue working with no grid power, but with sunlight and energy in the battery.
Thank you!
Multiplus-IIMPPT ControllersVenus GX - VGXEnergy MeterBYD
Murray van Graan avatar image
Murray van Graan answered ·
So long as your system is sized correctly, it will work.
Francisco Aroca avatar image Francisco Aroca commented ·
Thanks for the answer!
denzel avatar image
denzel answered ·
So, im trying to accomplish a similar scenario .
I have the Multi (AC-IN) fed from the grid and AC-OUT-1 to the DB . Currently if the grid fails the Multi takes over.
Now with ESS im hoping to achieve :
Primary power from the PV or Batteries
Should the PV or batteries not enough th
Use the Grid .
Im still reading up on ESS "Self-comsumption Hub-1"
Regards
Denzel
Hi @Denzel
This is where you want to read up:
https://www.victronenergy.com/live/ess:start
