When I turn on the VictronConnect app (iOS), it immediately tries to connect with the last connected Victron device. However, if I'm outside of the bluetooth range, instead of showing me the data from the last connected session, it immediately tries connecting and in so doing it obscures the data from the last connected session. So, for example, if I looked at the history data while standing next to the device, but then I walk 50 feet to my house, I'm unable to view the history data unless I go back and physically stand next to the device again. There should be an option to NOT attempt to auto-connect to the Victron device when you first turn on the app, so that you can review the most recently connected history data. As it is, I can only look at the history if I'm standing next to the device, and I'm not able to do it after I've moved outside of bluetooth range. Super annoying. This is for a charge controller, I don't know how it behaves for other devices.
