I need to be able to remotely turn my SmartSolar on and off from my BMS so i can cycle my LiFePo4 battery instead of having it charging all the time the sun is up.
At the same time i want to be able to read the data fro the VE-Direct port.
Is it possible, using my own cable, to use the RX pin as remote control and at the same time use the TX pin to transmit data?
