brittneywoodgate avatar image
brittneywoodgate asked
Turn Multiplus off using PLC
Hi, I am using a PLC to write and read reqisters from a Cerbo GX over Modbus TCP. I am using register 33 (switch position) to try turn the inverer on and off by sending units 3 or 4 . I have tried this and it seems to think it is off (VRM shows Inverter off) but there is still power so its not completely turning it off. Is there a way that this can be done?
The issue I'm having seems to be an issue with writing to the reister. I can read the register and when i turn the switch off over remote connect, the register reads 4 but when i write a 4 to the register, it doesnt seem to hold the value and nothing will turn off and the register is reading a 3 even though vrm and remote connect are indicating that the multiplus is off.
Multiplus-IIcerbo gxModbus TCP
@Brittney.Woodgate
This one's better suited to modifications, will move it there.
brittneywoodgate avatar image brittneywoodgate kevgermany ♦♦ commented ·
Thank you!
P.H.J. Sibbing avatar image
P.H.J. Sibbing answered ·
Use one of the relay positions of the Cerbo, or more (if more multipluses ? are in play) .
Either switch the power lines of with a relay or the Remote On/Off ports of a Multiplus (?), other products also have an Remote On/Off ports.
https://www.victronenergy.com/media/pg/MultiPlus-II_230V/en/UUID-b318472a-d96b-05c9-cdb8-5850fb6bb16d.html
Command can come from your PLC to an external relay to make or brake the Remote On/Off
I made Manual emergency switch to stop my multiplusses ( 3 in series with one wire in and out connecting the Remote On/Off ports) ) from operating , with an another switch to cut the power lines in and out.
