I am in the UK so we are talking the 230V versions
I read through the manual and it says that you can run up to 6 in Parallel
and it also says that "Only identical devices may be connected in parallel."
is there a way to run a 48/5000 and a 48/3000 in Parallel ?
they are both 48V...
If I set the 48/5000 as Master and the 48/3000 as Slave to only come on when needed
I would have liked two 48/5000's, but my DNO has told me I can only export 6.9kW !
