msmolow avatar image
msmolow asked
Two RV-C devices termination
I currently have a Lithionics battery BMS connected to the first CAN-bus port configured for RV-C with a VE Can RJ45 terminator in the second port. If I want to also add a SeeLevel 709 RVC do I simply remove the RJ45 terminator and use that port, or must I maintain a terminator? If so, how?
Thanks
cerbo gx
Kevin Windrem avatar image
Kevin Windrem answered ·
RV-C is a multidrop parallel connection. Devices can be daisy chained. Both ends of the bus need to be terminated. Intermediate taps should not be terminated.
msmolow answered ·
Nether the Lithionics BMS nor the SeeLevel 709 can be daisy chained because they each have only one port.
If the second Cerbo port requires a terminator, how can I include both the Lithionics and the SeeLevel?
Thanks.
Kevin Windrem avatar image Kevin Windrem commented ·
Should be easy enough to build a bus with taps to the three devices, then a terminator on each end of the bus.
Look up RS-485 for ideas.
msmolow answered ·
Thank you.
