Please see attached drawing for my proposed system - I have already bought the Multiplus ii 12/3000 and 4 x Bosch L5013 Leisure batteries.
I have seen in the Victron wiring unlimited info that the 12/3000 may need a 1000a shunt, is that correct or will a 500A be sufficient? I was planning to buy a smartshunt.
Wiring to/from the inverter and battery bank interlinks are 2x50mm2 with 2 x 200A fuses to protect the inverter connection. Also a 300A on the negative side of the leisure battery bank to protect that from vehicle short. Are any other fuses required/too small or large/in the wrong places? Hopefully my drawing is clear enough!
Also I have read about it being undesirable to go from TT to IT in terms of earthing arrangement, do I just run the CU earthing to the vehicle ground which is also connected to the earth of the inverter? I presume the inverter deals with fault current by linking the neutral and earth internally when the shore power is disconnected?
Any advice relating to any of that is helpful, thank you in advance! Is a BatteryProtect a good item to add to the system also? Where would this go? is anything else worth adding? I want no displays internally, all off the phone if possible, to go in a 7m class A motorhome.
