Hello.
I'm installing 6 Renogy 320 two strings 3, in parallel (8awg) to combiner box (8awg) to 150/70 mppt (2awg) to lynx using 4 12v Redodo 200ah plus Lifepo4 two string parallel 24v (4/0) to lynx powering a Sungoldpower 24v 4000w inverter charger (4/0) in a 2018 Coachman Freedom Liberty Express under the bed and the inverter is in pass-through with temperature actuated fans. AC lines from shore ran underneath to inverter then back to original WFCO destination.
My question among many. Can I install from lynx(24v) to the (2awg) Orion 24/12 70 to the existing 12v wires that lead to tounge battery ( instead of 12v battery use the 24/12 70) and not have to use a battery outside? And thus not having to change or alter STOCK converter WFCO.
This was the game plan and I'm all set to mount components to board and run wires.
