I am adding a new array to our system and I want to create an add on to that array of panels that will allow the system to track the sunlight as it moves across the sky. Has anyone done this and if so, are you willing to share any information on how you set it up? What components you used and how your solar tracking system functions? Sure would be great if Victron had an add-on gadget to make this easy!
