pommesfrites avatar image
pommesfrites asked
Lynx BMS Overheating while charging
Lynx Smart BMS is overheating with 12V 300A charge from alternators for 30 minutes.
I'm getting a BMS internal temperature too high alarm via bluetooth in Victron App. I have 2x 250A alternators regulated to a max of 150A each. Clamp amp meter confirms 300 Amps headed to a 600ah battery setup. In theory, I should be able to get pretty close to charging 50% of capacity in 1 hour. In reality, the BMS is overheating in about 25 minutes.
1) Has anyone upgraded heat dissipation? I'm thinking of adding a heat sink, or possibly using a PC computer's liquid cool system to transfer heat away from bms installation.
2) Does anyone know the temperature at which the BMS internal heat alarm signals? I will test with laser thermometer next time, but would love to know the spec, which isn't in the published manuals.
lynx bmsTemperature Alarm
11 comments
Are there consumers that discharge the battery at the same time (adds to the total current that flows through the contactor)?
Have you checked if the internal fan is running?
Show more comments
oldchubbyknuckle avatar image oldchubbyknuckle commented ·
Any update on this? Was it poor connections on the bus bar or lugs?
pommesfrites answered ·
I tested this this thoroughly, and become convinced it was not fasteners or cable crimps. I used a laser thermometer and carefully checked the temps on either side of each connection, looking for a delta. I could find none.
In the end, I decided that it must have been some unknown combination of the ambient temperature, a loose connection, or undersized alternator cabling. I rewired the alternators with 000 cables, and moved the batteries and bms to another location. I created all the new cable lugs and precisely torqued the fasteners.
Some combination of those solutions solved the problem. The bms doesn’t heat up past 40c, even when charging at 300 amps for an hour.
LED indications, warnings, alarm and error codes
Lynx Smart BMS product page
Lynx Smart BMS online manual
