I am facing an issue on my Multiplus-II 48 /3000 / 35-32 : All seems working correctly but the "Inverter On" LED is flashing continuously. This is strange. Where does it come from ? Is it a correct working mode ?
According to the device manual, this LED is flashing when the loads requires more current than the one allowed on the AC input. But in my configuration, this is not the case : the AC input is calibrated to 32A and the loads are never exceeding 2600 W (2600W / 220V = 12A << 32A). Even if this Inverter LED is flashing, the inverter do not take any current from batteries, this is well meaning that no additionnal curent is required.
Does someone have an idea ? Does it reflecting a bad configured parameter somewhere ?
