roger-1 avatar image
roger-1 asked
Multiplus ll error files log
My Multiplus ll switches off either during charge or discharge cycles for no apparent reason. No indicated errors on the visible messages/notifications/alarms et al. There has to be an event error audit trail leading up to the switchoff indicating a condition the Multi is not happy with?
It does frequently read the battery voltage incorrectly giving a low voltage warning (red light on inverter side) of 43V when the actual battery voltage is 52V!
Multiplus-II
kevgermany avatar image
kevgermany answered ·
Do you have a GX device in your system? Errors are logged there to VRM.
In any case, please check the wiring and all connections between the multi and the batteries. Could be a faulty connection, loose terminal, loose fuse.
