alterboy avatar image
alterboy asked
400 amp fuse
I am totally electronics illiterate but cant find anyone in the keys to work on my system . My multipluss 3000 is not charging or inverting either. Lights read low battery and main on. Bank has been in steady decline and is now around 40% . Solar is starting to bring that up . I dont get any reading on either side of the 400 amp fuse but it does not look blown. How do I check that fuse ?
THanks for any help
Alterboy
fuses
@Alterboy
How are you trying to do the reading?
What would be draining your battery if the inverter is not working?
alterboy answered ·
I am hooked to shore power with the battery charge on but it does not seem to be getting to the batteries . I dont have much on the dc side . Fans radio , There is the hot water heater though.
I am trying to measure both sides of the fuse with a multi meter. Black to ground bar and red to one or the other side of the fuse ......no reading .
THank you for the quick reply
hominidae avatar image hominidae commented ·
...my understanding of how to check if a fuse is blown, is to check for it's resistance between each pole with the multi meter. A fuse that is not blown will present itsself with zero resistance, like a piece of wire ... a blown fuse will show as a pice of dry wood ;-)
alterboy answered ·
I did have a HIGH TEMPERATURE problem this summer where we had to shut down the system till now when I can run the Air conditioner on shore power and cool things off.
pyrorider avatar image
pyrorider answered ·
Take the fuse out (when everything is shut down!) and use a multimeter to check continuity and resistance of the fuse
Fuses & fuse holders Product Page.
