My installation:
- 3x MPII 5kVA,
- 30 or 45kWh of EVE batterys in 2 or 3 Seplos BMS enclosures,
- 1x MPPT RS 450/200,
- 1x Fronius Symo 8kW inverter,
- 48 Longi 415Wp = 19,68kWp
The fronius would be placed after the Multiplusses in series.
Via mppt calculator i did different scenario's:
- 4 * 10 panels on the 450/200 and 8 panels in one string on the fronius;
with the excel in the 450/100:
Here i have 40 panels of 415 Wp = 16,6kWp on one 450/200 with a power of 11kW. Could someone explain to me if the ratio between kWp and kW has to be respected, or if the "90% to small" can ben believed?
Furthermore the excel gives me the notification that : "charge power is reduced to max MPPT tracker power".
With the other panels (only 8) i have 3,32kWp on my inverter. This is kinda small i guess, knowing that the charging current of the 450/200 is being limited on 200A?
- 4 * 9 panels on the 450/200 and 12 panels in one string on the fronius;
Here i have 36 panels of 415 Wp = 14,94kWp on one 450/200 with a power of 11kW. Here i am at 82%.
The excel doesn't give me the errorcode: "charge power is reduced to max MPPT tracker power".
With the other panels (12) i have 4,98kWp on my inverter. This is kinda small i guess, knowing that also here the charging current of the 450/200 is being limited on 200A?
- 4 * 8 panels on the 450/200 and 16 panels in one string on the fronius.
Here i have 32 panels of 415 Wp = 13,28kWp on one 450/200 with a power of 11kW. Here i am at 72%.
With the other panels (16) i have 6,64kWp on my inverter. This is kinda small i guess, knowing that also here the charging current of the 450/200 is being limited on 200A?
- 3 * 10 panels on the 450/200 and 18 panels in one/two strings on the fronius.
Here i have 30 panels of 415 Wp = 12,45kWp on one 450/200 with a power of 11kW. Here i am at 90%.
With the other panels (18) i have 7,47kWp on my inverter.
Is it better to use lesser strings (3 in stead of 4) and more panels per string, or use all the strings and put lesser panels per string?
Alle the panels would be put on the south side of a building with all the same amount of sunlight in 4 rows of 12 panels.
