btrippy avatar image
btrippy asked
Problem using input current limit and generator
Hello all,
I have a Multiplus 12 3000 120v, Smart Solar MPPT, Color Control and a Honda EU2200i. The gen can produce 15amps and I have 600 watts of solar. My goal is to charge an electric UTV with the system, initially via the generator and once the power demand drops with the solar.
I can charge my system fine with a 15a current limit with the Honda, but once I plug the UTV in, the Multiplus kicks the generator connection out and in.
When you first plug the UTV charger in (120v cable) the Multiplus begins to feed the UTV power. You can watch the watts climb on the color control, and when it hits 1500 watts, it disconnects the Honda gen (but continues to charge the UTV off of my house battery) and then restarts the Honda feed in 10 or 15 seconds and repeats this cycle over and over.
I've played with all the settings in the Multiplus that I can think of such as weak AC and dynamic current limiter but not having any luck. I don't think it's a problem with the gen as I can charge fine using the current limiter. All components have the latest firmware except for the Multiplus. I don't know if it's at the latest as I can't seem to find that info on the website as it seems to be "for professionals only."
Anyone run into this or have any ideas? Below is an export of my Multiplus settings.
TAB: General
System frequency 60Hz
Shore current 15.0 A
Overruled by remote checked
Dynamic current limiter unchecked
State of charge when Bulk finished 95.0 %
Battery capacity 300 Ah
Charge efficiency 0.95
TAB: Grid
Country / grid code standard None: (feeding energy from DC to grid not allowed)
Accept wide input frequency range (45-65 Hz) checked
AC low switch mains off 94 V
AC low switch mains on 101 V
AC high switch mains on 138 V
AC high switch mains off 143 V
UPS function unchecked
TAB: Inverter
PowerAssist checked
Assist current boost factor 2.0
Inverter output voltage 120 V
Ground relay checked
Inverter DC shut-down voltage 11.75 V
Inverter DC restart voltage 12.75 V
Low DC alarm level 12.75 V
enable AES unchecked
TAB: Charger
Enable charger checked
Weak AC input unchecked
Stop after excessive bulk unchecked
Lithium batteries checked
Use equalization (tubular plate traction battery curve) unchecked
Charge curve Fixed
Absorption voltage 14.10 V
Float voltage 13.80 V
Charge current 100 A
Repeated absorption time 1.00 Hr
Repeated absorption interval 7.00 Days
Absorption time 1 Hr
TAB: Virtual switch
TAB: Usage
Virtual switch usage Do not use VS
TAB: Assistants
TAB: Assistant Configuration
Assistants not used
Multiplus-II
boekel avatar image
boekel answered ·
Did you try with a lower 'shore current' limit?
5 comments
btrippy avatar image btrippy commented ·
Yes, just tried setting it to 14 amps but the same thing happened.. once it hits that limit, it cuts the generator off and feeds from my house battery.
I also made sure to top my house battery off so that it wasn't pulling any additional amps away from the gen, so basically everything the gen was producing was going to the UTV.
boekel avatar image boekel ♦ btrippy commented ·
And at 10A?
I'd watch via VE-config what the input AC is doing when this happens, usually you see the current climbing until the voltage drops a bit, etc.
But anyway, read this first:
https://www.victronenergy.com/live/multiplus_faq
btrippy avatar image btrippy boekel ♦ commented ·
I've tried a lower current limit and it just trips faster than if it was at 15a.
I read through that link (thanks for that!) and tried all the settings with the exception of weak ac and still having issues. Interestingly, one of the last resort ideas from the article said to try setting it to charger only (pass-through) and it's running like a champ. Unfortunately, that's not going to allow me to use solar to finish the charging job on the tail end.
I did watch the AC feed via VE-config (recorded it actually) and oddly when it tripped, it hadn't hit the limit.. or if it did, it didn't update fast enough as it appears the refresh rate on VE-config is about 1 second.
I did discover the firmware version via VE-Config. It's 2702413. Not sure how to tell if I have the latest version or not as it's behind a professional login.. I have a MultiPlus 12/3000/120-50 120v VE.Bus so hoping someone can tell me if I have the latest version.
JohnC avatar image JohnC ♦ btrippy commented ·
459 is the latest. If you have the kit & knowhow to update Multi firmware, have a go signing in to Victron Professional. It let me in, as a diy installer..
Not saying that will fix your issue either, something strange there. If you have VRM access, try activating the widgets relevant to the ac supply and studying the graphs to see if you can pick up a clue.
dchantry avatar image dchantry JohnC ♦ commented ·
Were you able to resolve this problem?
JohnC avatar image
JohnC answered ·
I note you have 'Overruled by remote checked'. So you're setting your input limit in the CCGX?
I too suffer Multi baulks at my genny (fault of the genny). It will retry, but it doesn't seem to do it 'over and over'. Your Honda is an inverter type and may well do that. Plug say a light into it's second outlet to see if it's not just the inverter within. I've had that too with a different (inverter) genny.
Just so you're not looking in the wrong place.. :)
Thanks for the reply. I gave that a shot but I didn't see the gen be the one to kick out. An excellent troubleshooting tip though which I much appreciate!
Paul B avatar image
Paul B answered ·
Drop the Charge amps down to say 20 amps This setting is under the charger selection of VE Config and set the current limit to about 10 amps
once this works you can then play around and increase the charge amps until you are stable with your generator.
The reason its probably dropping out is that the gernerator is being overloaded and thus the voltage falls away and the inverter disconnects the gen.
tilo avatar image
tilo answered ·
I am a little late... is it already solved?
Maybe the power factor of the UTV charger is somehow influencing the output of the generator, and causing the Multiplus to disconnect? If possible measure with an oscilloscope the waveforms of current and voltage, and if you detect a lot of distortion, you might try with an AC filter (choke) between the UTV charger and the Multiplus to improve the power factor of the UTV charger.
