3 phase system 3 x 3kva multiplus II
2 x blue solar 150/45 ve direct east west configuration equal PV power at 2070 kw each
Cerbo GX
ESS running ether keep batteries charged or optimize with battery life to 90%
Two x Freedom Won etower 5/4 52V total 10/8 kwh
Grid type: Other ( not compliant to any set grid system )
Grid setpoint 600W
Phases are not balanced ( nature of the load )
When battery is 100% full and PV exceeds the load then feedback occurs and the supply authorities prepaid meter, which has a tamper switch opens and grid power is then lost.
Any help would be most appreciated
