Hi all have just installed my victron essy solar and all good up and running in no time just one small thing that is bugging me is that on the color control it is not showing the battery % just showing the v is ther a way to show this
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
By the sounds of things this is because the battery monitor function in the Multiplus has not yet been setup or selected yet.
To set it up you need a MK3 to USB cable & VE configure software that you can download from the Victron site. Then you can specify the battery bank capacity & a few other things so that it properly tracks the battery capacity.
Then you need to select the intended/correct battery monitor source on the CCGX if it does not come up automatically, this is under;
Settings > System Setup > Battery Monitor > MultiPlus on VE Bus
This is the related extract from the CCGX manual;
5 People are following this question.
