I have a question about inverter cutoff voltage in my setup. I have 4 LifePO4 batteries with 100 amp BMS that recommend the cut off at 10.5v. which is where it is set.
We had a situation where we turned off the Genset and left the RV accidentally leaving on the AC on Auto. When we returned at the end of the day the batteries were completely off until I turned the genset on. We only had a limited time to charge on genset due to the "quite hours"
My goal would be to shut down the inverter early enough to save some for our 12v system like water pump and lighting.
What can I do here?
Thanks!
