I am on-grid. I do not intend to use UPS features. I plan to use multiplus II 5000 inverter.
I want to make an ESS system to attach a 16s2p 460Ah prismatic battery with 250amp Daly BMS to my home.
I have no solar, yet. For now I want to charge batteries during an off-peak period with my energy supplier and run my home on the stored energy during peak hours.
A couple of questions:
- I attach the multiplus II unit - AC1 connection, to my home distribution box via a suitable breaker ie 30amp. This is all that is required on the AC side?
- I set the unit as an ESS.
- I install an ET112 between my home consumer unit and my grid meter, and connect it to the multiplus using network cable or some sort of radio link.
- How do I program the multiplus to charge during set hours?
Thank you in advance, I am excited to be getting involved in this area.
