alan-falck avatar image
alan-falck asked
Multiplus II3kva re-boots for 60 seconds 10-15 minutes after grid failure
Multiplus II 48/3000/35-32
Software 2629481
Battery : 5,2 kva Hubble Lithium AM2
Hi, this Multiplus re boots for 60 seconds 10-15 minutes after grid failure, IE when grid resumes (load shedding). It does this every time (repeatable) over a 3 week period so far.
I have triple-checked the connectivity the grid, the loads, the neutral separation (critical & non-critical) insulation resistance etc.
Battery SOC is between 80 and 90%
FYI: two independent Victron installers have checked my settings
No alarms or errors reported
Any Ideas, thanks
Alan
TAB: General
System frequency 50Hz
Shore current 32.0 A
Overruled by remote checked
Dynamic current limiter unchecked
External current sensor connected (see manual) unchecked
State of charge when Bulk finished 95.0 %
Battery capacity 100 Ah
Charge efficiency 0.95
TAB: Grid
Country / grid code standard South Africa: NRS 097-2-1:2017
LOM detection AC input 1 Type B (grid code compliant)
Power ramp time 600 seconds
TAB: Inverter
PowerAssist unchecked
Inverter output voltage 230 V
State Of Charge shut-down 10.0 %
State Of Charge restart 20.0 %
Inverter DC shut-down voltage 44.00 V
Inverter DC restart voltage 45.00 V
Low DC alarm level 46.00 V
Do not restart after short-circuit (VDE 2510-2 safety) unchecked
enable AES unchecked
TAB: Charger
Enable charger checked
Weak AC input unchecked
Stop after excessive bulk unchecked
Lithium batteries checked
Charge curve Fixed
Absorption voltage 53.60 V
Float voltage 53.60 V
Charge current 35 A
Repeated absorption time 1.00 Hr
Repeated absorption interval 7.00 Days
Absorption time 1 Hr
TAB: Virtual switch
TAB: Usage
Virtual switch usage Do not use VS
TAB: Assistants
TAB: Assistant Configuration
Assistants not used
Multiplus-II
nickdb avatar image
nickdb answered ·
Is the multi logging any alarms or error states?
What is the battery BMS reporting wrt DCL, CCL etc?
Presume you mean AM2 5.5kWh?
To add, does this behaviour continue if during times of stable grid supply, you manually drop the supply breakers? Helps to eliminate grid issues which can be plentiful after load shedding, when the grid is heavily loaded.
nickdb avatar image
nickdb answered ·
Since you aren't using ESS, you could disable LOM.
The test I suggested would also clarify if it is external grid or not contributing.
You really need to check what the battery is reporting at this time via it's parameters/details tab.
There is not enough info here to help, some zoomed in charts of grid voltage/frequency, BMS min/max cell, DCL, CCL, Voltage and so forth might shed some light.
What is the state of the multi being logged - does it go into inverting at all?
alan-falck answered ·
Hi Nick I've added some additional info to the original post.
I have not yet gotten access to the battery BMS, but the battery ran fine (for a month) on my 5Kva Multiplus before this install.
Yes, if I manually drop the grid for a longish (30 -45 min) period the behaviour is the same but does not reboot if I shut down the grid for just a few min. So it does seem time-related.
I have monitored the grid extensively after load shedding and it appears to be stable (nothing unusual) Thanks for the suggestions.
Is there anything attached to AC2 (geyser or such?) that could be kicking in with a surge after being off for a period of time?
alan-falck avatar image alan-falck nickdb ♦♦ commented ·
No all heavy non-critical load are on another circuit
Thanks, grid voltage a little on the higher side, not the end of the world.
Where are you gathering stats from? Do you have a GX and is the battery CAN bus attached?
Sorry I addressed this a bit further down the post (it's a Venus Pi setup). The mains/Grid monitoring is a third-party sensor & Log
The Multi performs perfectly during mains failure, it inverts and supplies critical loads from the battery just fine. Battery current and voltages (manually measured) all look normal, It also switches back to the grid perfectly (60sec delay) after load shedding has ended. The battery recharges the used battery capacity without issues (at around 30A DC). When it reaches float status (or near float) or around 10 to 20 min it then reboots. This Multi does not have a CAN intrface.
Ordinarily you would want a smarter battery attached to a GX device which would enforce the battery limits communicated by the battery management.
In your setup the Multi has no clue what is happening in the battery, so it is quite likely that the BMS isn't happy or is asking the multi to charge less (for various reasons), eventually forcing it to intervene.
Personally I would never run a battery like this without using the BMS, a GX and DVCC to manage the charge/discharge.
Your settings seem ok, so since it sounds like a newer install, I suggest you consider implementing a GX and attach the CAN battery port to it. This would give you all the control and visibility you need to work out what is going on, assuming it doesn't outright resolve the behaviour.
Yes in hindsight not getting a GX with CAN was a mistake, I did however hope I would have stability with this very basic system
I will receive a Victron Approved battery next week (Pylontech) and conduct further testing.
Cool, just remember a pylon also needs to be attached to a GX, all the supported lithiums do.
I'm running Venus on a Pi on this install (a very tight budget system) using VE Bus to USB, I guess there is no way to use a CAN to USB adaptor? Or if CAN is supported over a Pi ?
Perhaps I best get a Cerbro
Unfortunately you will need a Cerbo or older venus if you can find one. I am fairly sure your issues will resolve once CAN and DVCC is enabled. Hubble themselves want this on in a victron ecosystem anyway.
Thanks for the help and for reviewing my settings
No prob. Let me know how it turns out.
Hi FYI after a firmware update to the Hubble AM2 Battery the inverter reboot (after Grid resume) problem went away.
