Multiplus II 48/5000 100/70
Location NL
Gridcode changed to germany. Only clickety relais for a while, then no exces pv power flows to the grid.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Location NL
Have you setup the ESS assistant and configured a negative grid setpoint, configured feed in excess pv? AC/DC coupled PV?
Whats your complete setup like?
There is not alot of information in your post to give you correct guidance.
Thanx for the quick reply.
Have not tried the ESS assistant. Info is a bit fragmented.
Pv panels JAsolar 380Wp
Victron mppt 250/100
Batterypack 4x12V each 110Ah
Cerbo
The ESS assistent is where configuration are what you seem to be looking for.
This needs to be installed on the multiplus using VEconfig. A correct grid configuration has to be configured in the multiplus aswell to allow feed in.
53 People are following this question.
