joshuaattridge avatar image
joshuaattridge asked
MQTT JS/TS Implementation
Hello All!
I am attempting to connect to the Victron MQTT broker using typescript using this package mqtt - npm (npmjs.com)
This is the code I currently have (I have replaced some parts with * to hide personal information but I can assure that these details are correct):
const mqtt = require('mqtt')
const TRUSTED_CA_LIST = `-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----`
function _get_vrm_broker_url(vrm_id: string) {
    var sum = 0
    for (var i = 0; i < vrm_id.length; i++) {
        sum += vrm_id.charCodeAt(i)
    var broker_index = sum % 128
    return "mqtt" + broker_index + ".victronenergy.com"
const client = mqtt.connect('mqtts://' + _get_vrm_broker_url('*****'), {
    username: '*****',
    password: '*****',
    ca: TRUSTED_CA_LIST,
client.on('connect', function () {
    console.log('connected')
However when I test this in the browser I get the following error message:
WebSocket connection to 'wss://mqtt91.victronenergy.com/' failed: Error in connection establishment: net::ERR_CERT_AUTHORITY_INVALID
I hope someone can tell me where I'm going wrong and lead me in the right direction,
thank you for your time!
Josh
MQTTjavascript
gone-sailing avatar image
gone-sailing answered ·
Try MQTT not WS as the protocol.
joshuaattridge avatar image joshuaattridge commented ·
thanks for replying so quickly,
I tried this and I get the same error, I added *protocolId: 'MQTT'* as one of the options on the mqtt.connect call.
Also I believe as this is coming from a browser you have to use web sockets rather than direct MQTT, but please correct me if I'm wrong.
There is nothing in the dbus-Mqtt documentation to suggest that web sockets is enabled in the VRM Mqtt servers. It seems it’s just MQTT over ssl.
https://github.com/victronenergy/dbus-mqtt
No it doesn't however the Victron web-app uses websockets victronenergy/venus-html5-app: HTML5 App including Javascript library that communicates with Venus OS over MQTT websockets (github.com) which suggests it is possible.
gone-sailing avatar image gone-sailing joshuaattridge commented ·
I believe that web app communicates with the MQTT server on your own local Venus GX device. You are trying to connect to Victron’s VRM servers.
joshuaattridge answered ·
So I finally figured out how to get this working.
If you want to have a MQTT connection Victron broker using a browser (Javascript/Typescript) then you need to have the following parameters:
host: wss://webmqtt***.victronenergy.com
username: YOURVRMUSERNAME
password: YOURVRMPASSWORD
I found out that Victron have another broker address that works with web sockets so on the address rather than having 'mqtt.' you need to have 'webmqtt.' I hope you find this useful please look at this programming example below:
    var sum = 0
    return "webmqtt" + broker_index + ".victronenergy.com"
const client = mqtt.connect('wss://' + _get_vrm_broker_url('YOURVRMDEVICEID'), {
    username: 'YOURVRMUSERNAME',
    password: 'YOURVRMPASSWORD',
    client.subscribe('#', function (err) {
        if (!err) {
            console.log('no error')
client.on('message', function (topic, message) {
    // message is Buffer
    console.log(topic.toString(), message.toString())
    client.end()
And thanks to @gone-sailing for the help you provided :D
taylortops avatar image
taylortops answered ·
Could you please show how you're handling the keepalive.
Yes of course.
So on the connection I have added a function that will loop every 5 seconds and publish to the keep alive topic
  (function theLoop() {
    setTimeout(() => {
      client.publish('R/YOURVRMDEVICEID/keepalive', '')
      theLoop();
    }, 5000);
taylortops avatar image taylortops joshuaattridge commented ·
Many Thanks. I found that 55secs was a nice interval.
goups avatar image
goups answered ·
As a side note, here are the settings to connect to the WebSocket with SSLcapture-decran-le-2024-03-05-a-133310.png
Is there a way to connect without SSL ? Which port ?
Victron MQTT readme
