I have trouble with my Cerbo CX. I wanted to update the firmware from 2.75 to the actual version 2.85
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Dont forget resetting it means it no longer has your wifi password. You have tomise its own AP.
Plug a normal hdmi screen in if possible and have a look and see what it is doing. You can also plug in a usb mouse to interface with it.
Is it not reachable by bluetooth in Victron Connect either?
If you followed the reset instructions it should work. Otherwise do it again.
Problem solved. Reseted everything with a Venus-data.tgz file from a 16GB SD card
Hello everyone, for a couple of days my Cerbo GX has stopped communicating with the Wi-Fi. Among other things, the blue LED (BT) no longer flashes and it is no longer detectable by the Victron Connect app.
Entering the menu through the remote console (access point in his intranet with a tablet) followed a reboot but had no resolution. The blue LED no longer flashes.
Going to the menu again, under Bluethooth I try to turn the BT on and off: No results.
I tried to connect to another Wi-Fi network as the pre-selected one fails to connect returning the "FAULT" message. Connected with the hot spot I downloaded the firmware version 3.00 and after restarting still nothing.
Among other things, after the update the "BLUETHOOTH" item disappeared from the menu, now it can no longer be turned on or off.
Inexplicably it is as if the WiFi had become lazy and the BT failed.
Can someone help me?
Thank you all.
35 People are following this question.
