Hey there,
When a Smart Battery Protect 12/100 is set in Li-ion mode, the BMS controls the shutdown when the battery reaches a certain low voltage. I am using a Ve Bus BMS. When in Li-ion mode, Victron Connect disables the shutdown setting on the Battery Protect. Where and by which device is this 'low voltage' level determined? is it programmed somewhere, or does the VE Bus BMS just know this value?
thanks for your help!
