Victron quattro 12/5000/220 inverter turning off / on every five seconds under load. (only when cold)
i have the above inverter, with new 840ah of AGM Batteries (6 x 6v run in 3 x 12v banks) , all new wiring 95mm2 to the inverter from the batteries.(2 x + and 2 times - ).........there is also 1.2kw of solar panels and a Rutland 914i wind turbine. when the inverter is turned on it will cycle on and off repeatedly....no fans come on (although the fans do attempt to move when cycling off)...............if i plug into shore power and turn the battery charger on even for a few minutes, unplug from shore power and it will work fine all day until switched off for any length of time. sometimes also setting everything to default via ve. config, will start it working. i have tried another main board, removed the psu and re-soldered any obvious dry joints.....still doing it. firmware is 1933159.(on both boards)...........anyone any ideas??
