I have a tree phase setup. After a firmware update the "Inverter on" led is dark on one of the units. The system works as normally and delivers power on all three phases. The led is working if I connect with the USB interface and use the "flash light" function.
The FW update was done through vrm portal. After this I have updated the FW again with the MK3 USB cable. Same result.
