Motorhome Avida Longreach has a Quattro 3000, MPPT 100/50 Charger, Smart Shunt, Color Control GX and a GX LTE -4G SA GPS fitted with 400 watts of solar on the roof.
The problem - the color control will read that the battery is 65% charged first thing in the morning. When the sun gets onto the solar panels and starts charging 20 - 30 watts, the Color controller GX battery reading change’s from 65% charged to 100% NO GRADUATED READINGS to fully charged and the 3 AGM Batteries are at 11.7 volts But reads 100%.
On a good sunny day the batteries are fully charged to 13.4 volts after 4 to 5 hours And the Color Control GX has been on at 100% all the time.
the Color Control GX settings Battery Monitor is set to Smart Shunt. Also getting a Connection Error #153 Connection error.
