peterkuiuphof avatar image
peterkuiuphof asked
VICTRON SMARTSOLAR MPPT 100/15 Shut
There is a possibility to switch the mppt off for maintenance.
Is this a problemen voor the mppt if you do this for a longer time and more frequent.
This is to protect the lifepo battery
or is it better to do this with a VE Direct non-inverting remote on/off cable
I don’t want to damage the mppt
MPPT Controllers
@peter.kuiuphof@gmail.com
There is no downside to using this feature to turn off the MPPT. The VE.Direct non-inverting remote on/off cable is used for automation, e.g. controlled by a BMS.
bramdvries avatar image
bramdvries answered ·
Thanks Stefanie, I was looking for that answer from a Victron staffer.
But then the warning in Victron Connect should be removed, not?
"Only use for maintenance" is apparently wrong and thus very confusing.
