Once in a while my charge controllers spend a very short amount of time in absorb phase, perhaps 20 minutes after bulk is through. In this case I just turn off the mppts and turn them back on and they quickly go through bulk and then properly perform the absorb phase. In these cases we have nothing but clear sky and hours of sun. I live in the high desert of Nevada. This morning I watched the bulk phase bring the batteries up to 94 percent and the switch instantly to float. Turned them off and back on, 30 seconds in bulk, the a quick orange led flash through absorb and straight into float. I spent the day reading in forums and testing the specific gravity of all 24 cells. Turning off batteries, pv array, rebooting everything, etc, all in a controlled way and nothing puts the system into absorb. Specific gravities suggest I’m between 70 and 80 percent charge. I finally gave up and tried running my generator through the Quattro and the Quattro goes quickly into absorb phase. What the heck do I try next? And why would this suddenly happen? I could use some helpful suggestions as I’ve read through hours of the forum and tried 6 different things and am at a loss as to what could be wrong. What a time suck (and gasoline). I have Quattro 10k, two smart solar MPPT 250/100. Cerbo gx, bmv 712, midpoint charge monitor, temp sensor into the bmv, 12 Rolls 4ks 27p flooded lead acids. I am using Dvcc sharing voltage, current, temp. No grid tie
Also a screenshot of your mppt settings.
