michaeltenerife avatar image
michaeltenerife asked
Which firmware is the right one to download betwenn group 433 and 459?
Hi everyone,
I went through other posts on the forum but I couldn't figure out the answer:
My Multiplus 48 3000 says 2622413 an on https://professional.victronenergy.com/downloads/firmware/ I find 2 different newer firmwares that fit the description of what I should use to update: 2622433 and 2622494. Which one should I use?
I have a pylontech 3000US battery if that might be important to know.
Thank you
firmware update
Always use the latest version. At the moment it is 494.
michaeltenerife answered ·
ok, thank you. I do that then. I don't understand why those other older ones are there, it is confusing....
Installed and config imported again. Everything seems to work all fine. Anything to be looking after just in case?
