jeroenw avatar image
jeroenw asked
Why is there a difference in max charger voltage versus max inverter voltage?
Hi, i was wondering why on a Multiplus II 48V the inverter can handle up to 66V (according to the datasheet) while the charger can only be set up to 64V max. (limited via the input field in the VEConfig app)
I understand that charging and inverting are two different things but i was expecting a similar voltage range for both. (Or is there perhaps a different way to set the charger voltage to 66V that i did not find...? I would love to get up to 66V on the charger!)
Thanks
Jeroen
Multiplus-II
gnagflow avatar image
gnagflow answered ·
I am looking for the same, did you find any solution?
