On a 2022 Transit with dual 250 amp alternators, the specs show vehicle amp draw at highway speeds of 100 amps, at idle 90. At idle, 1 alternator is about 176 amps and at 4000 rpm about 240 amps. Could the dual alternators handle 2 Buck Boost 100s if set at 75 each, total 150 amps? With 100 for the vehicle, that would total 250 or 50% total capacity. Thank you.
