techsol avatar image
techsol asked
Current Sensor on PV Inverter. Multi Plus II. 200W Solar Power at night - still after few days.
Hello.
I installed a solar inverter in parallel on the Multi Plus II input. I measure the solar inverter with a current sensor. After a few days of operation of the system, the sensor shows me at night about 200W of power on a solar inverter. What are your suggestions for solving this problem?
Multiplus-II
Paul B avatar image
Paul B answered ·
first off all you would need to check with a clamp meter that there is really no power going through the cable ie the Grid Tie inverter maybe consuming power, and the sensor may not be bi directional, otherwise it would need calibrating, and with out more information
like how its installed and what type of sensor is used there is not much else I can suggest
