I've compared the output voltage of 2 Victron solar panels I've just purchased and in lower lighting conditions my digital voltmeter reads approximately 6volts different for the same lighting conditions. In bright sun they both read approx 22 volts (the maximum open circuit voltage stated on the Victron data sheet). Should the readings in the lower lighting conditions be similar or is this an unfair test?
