Hullo out there. I am building a system for my camper van with a Multiplus 24/3000, using a shore power input. I see the manual recommends a bypass circuit for the case of a Multiplus failure. In all the threads I can find here, the recommendation is to install a 2 position, 2 pole switch for the shore power to feed either the inverter or the AC panel. However, that does not isolate the Multiplus- the AC2 out is still connected to the AC panel and thus is live. Does anyone have a suggestion for a switch that isolates the output as well as the input, for both line and neutral? I can do this with two switches but would prefer simultaneous action to prevent potentially deadly mistakes when servicing.
I am in Canada, so 120V/30A operation.
Cheers
Daniel
