twtch76 avatar image
twtch76 asked
Battery monitoring with multiple loads
I have a Multiplus II 2x 120 and a blue tooth dongle that I have installed in a fifth wheel camper. I have a 500Ah lifepo4 bank. Because it is a camper, the multiplus is not the only dc load on the battery bank. (lights, water pump, heater motor, slide motors, rams, etc....)_ When I look at the Victron Connect app which gives me a display of the multiplus II I see a battery % value. How accurate is this battery % given that there are additional loads on the battery bank? Does it somehow "Sense" how much is left or is it just keeping track of it by usage (software)?
Multiplus-II
Hi @twtch76 , and welcome to Community.
For your system, as like you explained it has more loads connected to the battery bank, it will need a battery monitor.
The % shown by the MultiPlus won't be reliable.
More is explained also here: https://www.victronenergy.com/media/pg/Cerbo_GX/en/configuration.html#UUID-3d1bea6f-30a0-7d84-8ba6-dab25033ba16..
You could add a Victron SmartShunt; and then connect to that using VictronConnect. And to go "all the way" you could go to a GX device, such as the Cerbo GX which manual I linked above.
Have a good weekend, Matthijs
