Hi there,
Is there any SLD or connection diagrams available for following setup?
Can someone please guide us for our first install with Victron? Any suggestions or tips?
I have attached BOM as well
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Hi there,
Thanks
Hi
Make sure all inverters are running the latest firmwares this applies the Fronius units as well.
You can use the VE configure on the phone app to do 2 parallel units OK. You will need to use the PC or laptop to install the ESS assistant as required into both units, this is were you setup charge control, grid control, etc.
Just a Note: you should do some sort of training for parallel systems and how they are wired etc
As it is all critcal to get this wright with the correct cable and cable lenghts for AC and DC very important.
Regards
Rob D
NZ
43 People are following this question.
