I would like to switch an air conditioning system automatically. The rules are simple:
If the SOC> 98% it should start and if the SOC <60% it should stop and it shoul stop also if another system uses 1000W.
So the rule is exactly the opposite of the generator rule. Unfortunately, this cannot be inverted. You could use a switching relay that inverts the generator circuit?
How would you solve that?
