Hello i want program my bluesolar for lifepo4 batterie anyone have mpptprefs.exe it impossible to download and vitronconnect not supported thanks you
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
It is available via Victron Professional. You can register there for free and download it.
Alternatively, I put it in a ZIP file, attached to this post.
BR
looking for that program I found:
We recommend to use VictronConnect instead of mpptprefs. Much simpler and faster to use. Also it includes automatic firmware updates.
I use some hand crafted code running with my BMS system to dynamically limit the charge current from the Blue Solar charge controller. With lithium batteries this is required - or you need a disconnect relay in the PV side of the MPPT. Thus when a cell achieves maximum charge, the charge current is reduced. Trying to do this with a voltage set point won't work well, as a single cell will reach maximum voltage first. Calculating the maximum pack voltage by n X max cell voltage can lead to an over voltage situation.
Je sais cela mais pour l instant je n ai que un bluesolar 70/15 non peis en charge par victron connect je vais augmenter mes panneau pour mes lifepo4 elle ne sont pas communicante je voudrais juste limiter la tension de charge a 13.9 et le floating a 13.2 vivant sur mon bateau je peu couper mes pv quand je suis a 100% ou avant sur les nouveau mppt on peut couper l absorption lorsque le courant absobez diminue a 2 A je pense que ca peut remplacer le relais votre solution est bien mieux mais avec des baterries sceller MOIns facile a moins de les ouvrir le bms a une interface de communication can merci de vos renseignement avez vous un gitub pour votre bms bonne soiree
Please excuse - my French is not quite up to speed.
The link for the serial bms project is on GITHUB at: -https://github.com/Louisvdw/dbus-serialbattery/tree/spi-battery
My SPI battery / BMS is a derivative of this, using much of the same code. I produce a BMS card, powered by a Raspberry Pi, this runs either Raspian or Venus OS (Tested to 2.71).
I used the mppt control / display from Victron to program the original blue solar 100/50, if you don't have this I guess the mpptprefs program will still work.
With the Lithium batteries you HAVE to watch the individual cell voltages and reduce the charge current when the first cell reaches its maximum. Watching the pack voltage or current will not avoid one cell going over voltage. Under voltage limits too are more critical.
Veuillez excuser - mon français n'est pas tout à fait à jour. Le lien pour le projet serial bms est sur GITHUB à l'adresse : -https://github.com/Louisvdw/dbus-serialbattery/tree/spi-battery Ma batterie SPI / BMS est un dérivé de cela, utilisant une grande partie du même code. Je produis une carte BMS, alimentée par un Raspberry Pi, qui fonctionne soit Raspian soit Venus OS (Testé à 2.71). J'ai utilisé le contrôle / affichage mppt de Victron pour programmer le 100/50 solaire bleu d'origine, si vous ne l'avez pas, je suppose que le programme mpptprefs fonctionnera toujours. Avec les batteries au lithium, vous DEVEZ surveiller les tensions individuelles des cellules et réduire le courant de charge lorsque la première cellule atteint son maximum. Surveiller la tension ou le courant du pack n'évitera pas qu'une cellule passe en surtension. Les limites de sous-tension sont également plus critiques.
Mike
56 People are following this question.
