I have a Multiplus 2 3KVA inverter with a VE 150V 60amp solar charge controller, 9 CS 365W panels and a GX controller. The system works fine and produces power and then the next day the solar array will suddenly stop producing power. Sometimes it resets itself and starts working again and sometimes I have to do a remote reset. Sometimes the remote reset works and sometimes it does not.
I do not know what the problem is and would appreciate help to find the issue.
  Hello av1um, thank you for responding to my question.
