stitch-up avatar image
stitch-up asked
Update Fails Victron Energy Blue Smart IP22 Charger 12/30(3)
I just received a brand new Victron Energy Blue Smart IP22 Charger 12/30(3) purchased from Amazon. I already own the Victron, smart solar charge controller with built-in Bluetooth.
I switched the charger on and paired it via bluetooth to my Samsung S20 - no problems there. When connected to the charger I was prompted to update the firmware, I had a very solid internet connection and the update process started, reached about 8% and failed with an X88 error. I tried many times to update the firmware with the same failure. Now when I switch the charger on I get fast alternate flashing red LEDs. I'm still able to connect to the charger and it now says - update firmware from none to 3.4 however, I get the same failures!
I'm about to repackage and return the item for a refund unless I get a solution to my issue.
Regards
John
chargerVictronConnectfirmware update
Good to here that the update completed in the end. I do would like to point out that an internet connection is not needed for a firmware update. All firmware is included within VictronConnect and is thus not downloaded from the internet.
Kind regards,
Thiemo van Engelen
No need to "pair" your phone with the charger, just start VictronConnect.
Can you try to use another phone?
Create a service report after a failed update and attach that report here.
https://www.victronenergy.com/media/pg/VictronConnect_Manual/en/troubleshooting.html#UUID-98bc9211-902b-01a0-96b9-1f314c4d63c5
stitch-up answered ·
Thanks for the reply Matthias, perhaps I should have clarified - when I say 'pair' I mean I enter the 000000 to connect.
I've managed to reach 92% but it then fails again with an X95 error! I will try another phone when one becomes available later :)
Old phone became available and updated without issues - how strange and thanks again.
John
Using the Samsung Galaxy s10 Plus 5G = wouldn't update at all.
Using a Samsung Galaxy S7 Plus and it updated perfectly. :)
VictronConnect Manual
Download for iOS / Android / Mac / Windows
