johann avatar image
johann asked
Venus and Outback MPPT's
Good morning,
I have a fairly old installation with a 48/10000 victorn inverter, 3 x Outback charge controllers and 2 x 460amp/48v lead acid batteries.
I would like to add the Venus monitoring to the system. Would the Venus accept the inputs from the Outback MPPT's?
Thank you in advance.
Johann
Venus GX - VGX
Paul B avatar image
Paul B answered ·
you would need to install a BMV712 Battery monitor and then you would be able to see the current and the voltage coming into the venus under DC Loads or similar.
there is no way that I know of to connect the outbacks as they dont have the victron interface
