Hi i got 4 smart solar MPPT 100/20 and want to charge one 48 V Battery. I decide to purchase 4 MPPTs,because it is not recommended to install optimizers....... according to the manual i can select 1 as Master und 3 a slave. But if the master shut off due low sun, the other also stops charging?? My question is now, is it better not to connect the MPPT by ve.smart network and let each one work with the best sun level? something else to consider? If possible without secondary effect, can i monitor and edit each single mppt by my mobile?
