samuil avatar image
samuil asked
5-pin Relay with Victron MPPT
I am basically trying to have my system cut the load off at night and turn on during the day only. Therefore I have purchased a 5 pin relay to do the inverse of the 'street light' function in the Victron application.
I was hoping I could get some assistance with the wiring as I am a little confused. Please see my pre-schematic below:
Your help would be much appreciated as I've had no luck finding any existing schematics on Google, none of which were interfaced with a solar charge controller.
I am using the MPPT 75/15 and a 120Ah deep cycle AGM battery.
MPPT ControllersRelayStreetlight
mikhail-petukhov avatar image mikhail-petukhov commented ·
@Samuil try this way -
For load switching you have to use NC pins 30 and 87a - they are connected together by default. In case of MPPT 75/15 activated load output by 'street light' function it will powered relay coil and drop connection between pins 30 and 87a.
Battery voltage and relay coil voltage should be the same.
MPPT Product Page
MPPT Error codes
