Hi. I need to know if the Victron MultiPlus-II GX 3000VA 24V is a good choice for my needs or if exist a best alternative.
I need to configure the system to get the first amount of power (for example the first 50W) from the grid (to be sure to never inject to the grid).
The subsequent power from the batteries up to a set quantity: for example 2400W manually set in summer or 1000W in winter.
If the load exceed the capacities of the inverter, take the remaining part from the grid.
Change these parameters locally or via internet.
I don't need to charge the batteries from the grid. They are charged by a independent system
Thank you
